Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly. Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive. Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
  • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
  • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Trata de mantener las tiras adhesivas planas y sin arrugas durante el proceso; las tiras dobladas o arrugadas se pegarán y romperán en vez de despegarse fácilmente.
Adicionalmente, no presiones la batería al jalar de las tiras. Presionar la batería crea puntos de presión que pueden engancharse y romper el adhesivo.
Despacio tira de una lengüeta alejándote de la batería hacia la parte inferior del iPhone.
Jala constantemente manteniendo tensión constante en la tira hasta que salga de entre la batería y la caja trasera. Para mejores resultados, jala de la tira a un ángulo tan bajo como sea posible, sin engancharla en ninguno de otros componentes del iPhone.
La tira se estirará múltiples veces su largo original. Continúa jalando y sujetando la tira cerca del la batería si es necesario.
Si las lengüetas adhesivas de la batería se rompen durante el proceso de removerlas, usa tus dedos o pinzas desafiladas para recuperar el largo restante del adhesivo y continuar jalando.
Si cualquiera de las tiras adhesivas se rompen por debajo de la batería y no puede recuperarse, intenta remover el resto de las tiras y luego procede como se explica más abajo.
