Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 3
Next, the motherboard should still be connected by a wire that leads to the bottom portion of the phone. To remove the black plastic piece there is one screw that needs to be removed then you can pry it off with the plastic opening tool. To remove the black plastic piece there is one screw that needs to be removed then you can pry it off with the plastic opening tool.
  • Next, the motherboard should still be connected by a wire that leads to the bottom portion of the phone.
  • To remove the black plastic piece there is one screw that needs to be removed then you can pry it off with the plastic opening tool.
Insertar traducción aquí
