Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Detach the wires from the opposite end of the frame using the flat end of the Spudger. You can’t see where the wires are attached because it is hidden underneath the white frame. Make sure both wire attachments are fully disconnected before continuing.
  • Detach the wires from the opposite end of the frame using the flat end of the Spudger.
  • You can’t see where the wires are attached because it is hidden underneath the white frame.
  • Make sure both wire attachments are fully disconnected before continuing.
Insertar traducción aquí
