Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Using a metal spudger,  push down between the edge seals on the base and pry off the base. Do not confuse the top thin layer of rubber with the thick palette that needs to be removed. This may require substantial force.
  • Using a metal spudger, push down between the edge seals on the base and pry off the base.
  • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
  • This may require substantial force.
Insertar traducción aquí
