Saltar al contenido principal
Inglés
Español
Traduciendo paso 3
Paso 3
Tighten the drain plug using the 10mm hex. Fill the transfer case with the ATF oil using the vacuum oil pump. When the case is full, oil will begin dripping out of the fill hole.
  • Tighten the drain plug using the 10mm hex.
  • Fill the transfer case with the ATF oil using the vacuum oil pump. When the case is full, oil will begin dripping out of the fill hole.
  • Insert and tighten the filler plug using the 10 mm hex.
  • Be careful to line up each plug carefully to prevent cross-threading. Do not overtighten the plugs, as overtightening may cause the threads to strip.
  • Due to limited resources the transfer case oil was not actually changed.
Insertar traducción aquí
