Saltar al contenido principal
Inglés
Español
Paso 2
Set the drain pan underneath the transfer case. Make sure that the drain pan has enough room for about 2 quarts of oil. Locate the drain plug just left and under the filler plug.
  • Set the drain pan underneath the transfer case. Make sure that the drain pan has enough room for about 2 quarts of oil.
  • Locate the drain plug just left and under the filler plug.
  • As soon as the filler plug is removed the Transfer case oil will begin to drain. Take caution when removing the drain plug.
  • Due to limited resources, the transfer case oil was not actually changed for this guide.
  • While applying pressure towards the front of the car unscrew the drain plug with the 10mm Hex. Once you feel that the Plug is fully unthreaded quickly pull the plug away allowing the oil to drain.
  • The oil will take upwards of 5 minutes to completely drain.
Insertar traducción aquí
