Saltar al contenido principal
Inglés
Español
Traduciendo paso 2
Paso 2
If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine. Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay. Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
  • If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine.
  • Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay.
  • Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
  • Dispose of your used coolant at an auto parts shop or a landfill that accepts hazardous materials. Do not pour it down a storm drain or sink.
  • Remember to refill the reservoir tank with coolant before driving your Dodge truck. Driving without coolant will cause overheating and engine damage.
  • Due to limited resources the coolant was not actually drained in this guide.
Insertar traducción aquí
