Saltar al contenido principal
Inglés
Español
Traduciendo paso 3
Paso 3
Locate the differential filler plug. Use a #2 flathead screwdriver to lift the outer lip of the plug.  Pinch the outer lip of the rubber filler plug between your fingers and pull off.
  • Locate the differential filler plug.
  • Use a #2 flathead screwdriver to lift the outer lip of the plug. Pinch the outer lip of the rubber filler plug between your fingers and pull off.
  • Use a vacuum pump to pump in new differential fluid until the oil level reaches the bottom of the plug hole.
  • Re-insert the rubber filler plug.
  • Due to limited resources the differential oil was not changed in this guide.
Insertar traducción aquí
