Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential. Position an oil pan under the differential.
  • Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential.
  • Position an oil pan under the differential.
  • Loosen the bottom 4 bolts first with the 14mm socket wrench. Slowly loosen the rest of the bolts in a random order until oil flows out and enters the drain pan.
  • Due to limited resources the oil was not actually replaced in this guide.
Insertar traducción aquí
