Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard. Before installing the new fan, remove all remnants of thermal compound from the top of the CPU.  Warning—the stuff is hard to clean off clothing.  Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat.  Be sure the mating fan heat sink is clean.
  • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
  • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Warning—the stuff is hard to clean off clothing. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
  • Follow iFixit's guide for [enlace de guía no válido] for a detailed explanation.
Insertar traducción aquí
