Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact. If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced Use the plastic opening tool to gently pry the connector up from the motherboard.
  • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
  • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
  • Use the plastic opening tool to gently pry the connector up from the motherboard.
  • You can now safely remove the keyboard.
Insertar traducción aquí
