Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw.  One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover. Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
  • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
  • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
  • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
Insertar traducción aquí
