Saltar al contenido principal
Inglés
Español
Traduciendo paso 4
Paso 4
Support the unit in one hand to remove tension from the wiring harness. Pinch the multi-wire connector and pull away from the unit to disconnect. Note the location and orientation of your RCA cables to aid in re-installation.  It is usually most useful to take a picture of the cables in place before removal.
  • Support the unit in one hand to remove tension from the wiring harness.
  • Pinch the multi-wire connector and pull away from the unit to disconnect.
  • Note the location and orientation of your RCA cables to aid in re-installation. It is usually most useful to take a picture of the cables in place before removal.
  • Remove the 4 RCA cords by simply pulling them out of each jack.
Insertar traducción aquí
