Saltar al contenido principal
Inglés
Español
Paso 3
Note the locations of the wires and where they are attached.  If you happen to dislodge the wires during removal you will be able to re-attach them upon re-installation. Locate and remove the four anchoring 12mm long #2 Phillips screws for the head unit using the #2 screwdriver. It is now safe to pull out the head unit. Support it in one hand to reduce tension in the cables.
  • Note the locations of the wires and where they are attached. If you happen to dislodge the wires during removal you will be able to re-attach them upon re-installation.
  • Locate and remove the four anchoring 12mm long #2 Phillips screws for the head unit using the #2 screwdriver.
  • It is now safe to pull out the head unit. Support it in one hand to reduce tension in the cables.
Insertar traducción aquí
