Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver. Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off. Expect to hear popping as you pull the back panel off.
  • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
  • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
  • Expect to hear popping as you pull the back panel off.
Insertar traducción aquí
