Inglés
Español
Paso 4
Disconnect the ribbon cables so that you can peel back the keyboard ribbon cable to free it. Remove the 5 mm screw from the chip under the metallic ribbon next to the memory card and disconnect the chip. Use a #0 Phillips screwdriver. Remove the 5 mm screw from the chip under the metallic ribbon next to the memory card and disconnect the chip. Use a #0 Phillips screwdriver.
  • Disconnect the ribbon cables so that you can peel back the keyboard ribbon cable to free it.
  • Remove the 5 mm screw from the chip under the metallic ribbon next to the memory card and disconnect the chip. Use a #0 Phillips screwdriver.
Insertar traducción aquí
