Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver. Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off. Expect to hear popping as you pull the back panel off.
  • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
  • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
  • Expect to hear popping as you pull the back panel off.
Insertar traducción aquí
