Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 2
Pry open the two plastic hooks using the metal spudger tool. Crack open the black plastic cover using the metal spudger tool. The cover should be easily turned over. The connector might  get stuck in the opening while turning over the cover. Twist the connector if needed.
  • Pry open the two plastic hooks using the metal spudger tool.
  • Crack open the black plastic cover using the metal spudger tool. The cover should be easily turned over.
  • The connector might get stuck in the opening while turning over the cover. Twist the connector if needed.
Insertar traducción aquí
