Saltar al contenido principal
Inglés
Español
Paso 3
Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.) Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
  • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
Insertar traducción aquí
