Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame. Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it. Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
  • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Insertar traducción aquí
