Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove two 14 mm Phillips #2 screws. Remove two 12 mm Phillips #2 screws. Lift the arm off the assembly. This will reveal the tank hole as shown.
  • Remove two 14 mm Phillips #2 screws.
  • Remove two 12 mm Phillips #2 screws.
  • Lift the arm off the assembly. This will reveal the tank hole as shown.
  • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
Insertar traducción aquí
