Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 6
Remove the five screws securing the logic board connector bracket to the rear case: One 1.3 mm Phillips #000 screw
Unscrew the logic board connector cover
  • Remove the five screws securing the logic board connector bracket to the rear case:
  • One 1.3 mm Phillips #000 screw
  • One 1.5 mm Phillips #000 screw
  • Three 1.2 mm Y000 screws
  • Remove the bracket.
  • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
Remueve los cinco tornillos que sujetan el soporte del conector de la placa lógica a la caja trasera:
Un tornillo Phillips de 1.3 mm
Un tornillo Phillips de 1.5 mm
Tres tornillos Y000 de 1.2 mm
Quita el soporte.
Ten cuidado de no perder el soporte más pequeño que está enganchado al borde. Está sujeto con un pequeño clip y es muy fácil de sacarlo del soporte más grande accidentalmente.
[title] Unscrew the logic board connector cover
[* black] Remove the five screws securing the logic board connector bracket to the rear case:
[* red] One 1.3 mm Phillips #000 screw
[* orange] One 1.5 mm Phillips #000 screw
[* yellow] Three 1.2 mm Y000 screws
[* black] Remove the bracket.
[* icon_note] Be careful not to lose the [https://d3nevzfk7ii3be.cloudfront.net/igi/BLoNCtTggDqOfLxl|smaller bracket|new_window=true] clipped onto the edge. It's secured with a [https://d3nevzfk7ii3be.cloudfront.net/igi/XcoV2gOk5ISoxJLN|small clip|new_window=true] and is easy to accidentally knock off of the larger bracket.
