Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 7
Use the tip of a spudger to pry the front sensor assembly connector up from its socket. Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
Disconnect the front sensors
  • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
Usa la punta de un spudger para levantar el conector de ensamblaje del sensor frontal de su zócalo.
[title] Disconnect the front sensors
[* black] Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
