Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 5
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
Lift the display slightly
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Insert an opening pick into the gap.
  • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
Tira hacia arriba de la ventosa con una presión firme y constante para crear un ligero espacio entre el panel frontal y la caja posterior.
Inserta una púa de apertura en el espacio libre.
El adhesivo impermeable que mantiene la pantalla en su lugar es muy fuerte; La creación de esta brecha inicial requiere una cantidad significativa de fuerza. Si tienes dificultades, aplica más calor y mueve suavemente la pantalla hacia arriba y hacia abajo para debilitar el adhesivo hasta que cree un espacio para insertar la herramienta.
[title] Lift the display slightly
[* black] Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
[* black] Insert an opening pick into the gap.
[* icon_note] The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
