Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Power off your iPhone before beginning disassembly.
  • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
  • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
Antes de comenzar, descarga la batería de tu iPhone por debajo del 25%. Una batería de ión de litio cargada puede prenderse fuego y/o puede explotar si se la perfora accidentalmente.
Apaga tu iPhone antes de comenzar a desmontar.
Remueve los dos tornillos pentalobe de 6.7 mm en el borde inferior del iPhone.
Abrir la pantalla del iPhone comprometerá los sellos impermeables. Ten sellos de repuesto listos antes de proceder con este paso o ten cuidado y evita la exposición a líquido si vuelves a ensamblar tu iPhone sin reemplazar los sellos.
[* icon_caution] Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
[* black] Power off your iPhone before beginning disassembly.
[* red] Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
[* icon_note] Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
[* icon_reminder] There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
