Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 7
Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display. If the sensor does not wiggle free after a few seconds, apply more heat and try again.
Lift the ambient light sensor
  • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
  • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
  • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
Usa pinzas para mover el sensor de luz ambiental y levántalo de su muesca en la pantalla.
Si el sensor no se suelta después de unos segundos, aplica más calor e intenta nuevamente.
El sensor permanece unido al resto del ensamblaje del sensor a través de un cable plano muy delgado. Ten cuidado de no forzar o dañar el cable.
[title] Lift the ambient light sensor
[* black] Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
[* icon_note] If the sensor does not wiggle free after a few seconds, apply more heat and try again.
[* icon_caution] The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
