Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 5
Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module. Gently wiggle and lift to separate the module from its notch in the front panel. It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
Pry up the proximity sensor
  • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
  • Gently wiggle and lift to separate the module from its notch in the front panel.
  • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
Trabajando de izquierda a derecha, desliza una púa de apertura debajo del cable flexible y debajo del sensor de proximidad + módulo iluminador de inundación
Suavemente mueve y levanta para separar el módulo de la muesca en el panel frontal.
Es útil levantar y mantener el altavoz fuera del camino para acceder. Solo ten cuidado de no tirar del cable flexible delgado mientras trabajas.
[title] Pry up the proximity sensor
[* black] Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
[* black] Gently wiggle and lift to separate the module from its notch in the front panel.
[* icon_note] It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
