Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case. This requires a good amount of force. Work slowly.
  • Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case.
  • This requires a good amount of force. Work slowly.
  • It may be helpful to use an edged tool to separate the adhesive from the click wheel on the inside of the Nano while pressing it down from the outside.
  • Remove the click wheel from the inside of the Nano.
  • Be careful not to let the click-wheel slide on the metal plate supporting it, as it will break the flat cable. Apply force perpendicular to the click-wheel.
Insertar traducción aquí
