Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 6
Remove the five screws securing the logic board connector bracket to the rear case: One 1.3 mm Phillips screw
Unscrew the logic board connector cover
  • Remove the five screws securing the logic board connector bracket to the rear case:
  • One 1.3 mm Phillips screw
  • One 1.5 mm Phillips screw
  • Three 1.2 mm Y000 screws
  • Remove the bracket.
  • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
Remueve los cinco tornillos que sujetan el soporte del conector de la placa lógica a la caja trasera:
Tres tornillos Y000 de 1.2 mm
Un tornillo Phillips de 1.5 mm
Un tornillo Phillips de 1.3 mm
Ten cuidado de no perder el pequeño soporte que está enganchado al soporte de conector. Esta sujeto con un pequeño clip y es muy fácil de sacarlo del soporte más grande accidentalmente.
[title] Unscrew the logic board connector cover
[* black] Remove the five screws securing the logic board connector bracket to the rear case:
[* red] Three 1.2One 1.3 mm Y000 screwsPhillips screw
[* orange] One 1.5 mm Phillips screw
[* yellow] One 1.3Three 1.2 mm Phillips screwY000 screws
[* black] Remove the bracket.
icon_note] Be careful not to lose the [https://d3nevzfk7ii3be.cloudfront.net/igi/BLoNCtTggDqOfLxl|smallhttps://d3nevzfk7ii3be.cloudfront.net/igi/BLoNCtTggDqOfLxl|smaller bracket|new_window=true] that's clipped onto the connector bracketedge. It's held onsecured with a [https://d3nevzfk7ii3be.cloudfront.net/igi/XcoV2gOk5ISoxJLN|small clip|new_window=true] and is easy to accidentally knock off of the larger bracket.
