Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 6
Locate and disconnect the 4 ribbon wires from the top case. Locate and disconnect the two additional connecting wires. Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
  • Locate and disconnect the 4 ribbon wires from the top case.
  • Locate and disconnect the two additional connecting wires.
  • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
  • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
Insertar traducción aquí
