Saltar al contenido principal
Inglés
Español
Traduciendo paso 2
Paso 2
If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device. Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket. Slide the hard drive out of its seat.
  • If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device.
  • Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket.
  • Slide the hard drive out of its seat.
Insertar traducción aquí
