Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it. After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it. After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
  • After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
Insertar traducción aquí
