Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 4
The antenna cable connector and socket are fragile. Use the point of a spudger or fine tweezers to gently pry the antenna cable connector straight up off its socket on the logic board. To reconnect the cable, use tweezers to position it carefully over its socket on the logic board, and then press it straight down until it snaps into place.
  • The antenna cable connector and socket are fragile.
  • Use the point of a spudger or fine tweezers to gently pry the antenna cable connector straight up off its socket on the logic board.
  • To reconnect the cable, use tweezers to position it carefully over its socket on the logic board, and then press it straight down until it snaps into place.
  • If you need more slack in the cable, you can temporarily pry it from the clips securing it to the antenna plate.
Tira suavemente del cable o usa la punta de un spudger para levantar su conector directamente de su zócalo en la placa lógica.
Para volver a conectar el cable, usa pinzas para colocarlo cuidadosamente sobre su zócalo en la placa lógica, y luego presiónalo firmemente hasta que encaje en su lugar.
Si necesitas más holgura en el cable, puedes separarlo temporalmente de los clips que lo sujetan a la placa de la antena.
[* black] Gently pull theicon_caution] The antenna cable or useconnector and socket are fragile.
[* black] Use
the point of a spudger or fine tweezers to lift itsgently pry the antenna cable connector straight up off its socket on the logic board.
[* icon_reminder] To reconnect the cable, use tweezers to position it carefully over its socket on the logic board, and then press it straight down firmly until it snaps into place.
[* black] Use
[* icon_reminder] If you need more slack in the cable, you can temporarily pry it from the clips securing it to the antenna plate.
