Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable. With the Mac mini's ports facing you, carefully lift the antenna plate and slide it about an inch to the right.
  • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
  • With the Mac mini's ports facing you, carefully lift the antenna plate and slide it about an inch to the right.
No retires por completo la placa de la antena; Todavía está conectado a la Mac mini con un cable de antena
Con cuidado, levanta la placa de la antena para poder acceder al conector del cable de la antena que se encuentra debajo.
Con los puertos de la Mac mini frente a ti, el lugar más seguro para levantar la placa de la antena es desde el lado derecho.
[* icon_caution] Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
[* black] Carefully flip up the antenna plate to allow access to the antenna cable connector underneath.
[* icon_note]
With the Mac mini's ports facing you, the safest place tocarefully lift the antenna plate is fromand slide it about an inch to the right sideright.
[* icon_note]
