Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Make sure the device is unplugged. Then, turn over the device so that the label is readable. Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver. You need a spudger to orient the bottom screws so that they can be removed.
  • Make sure the device is unplugged. Then, turn over the device so that the label is readable.
  • Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver.
  • You need a spudger to orient the bottom screws so that they can be removed.
Insertar traducción aquí
