Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Turn down the squared tabs on the brushbar so that they face outward. Use a screwdriver to pry the belt up from the brushbar.
  • Turn down the squared tabs on the brushbar so that they face outward.
  • Use a screwdriver to pry the belt up from the brushbar.
  • Be careful not to cut the belt with the screwdriver.
  • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
  • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
  • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
Insertar traducción aquí
