Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board. Take care not to pry under the socket, or you may break it off the board.
  • Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
  • Take care not to pry under the socket, or you may break it off the board.
Levanta con cuidado el conector de la luz indicadora LED hacia arriba para desconectarlo de su zócalo en la placa lógica.
[* black] Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
[* icon_caution] Take care not to pry under the socket, or you may break it off the board.
