Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 4
In this step, you'll push the logic board free from the clips holding it to the frame. Push only where directed or you may damage the fragile cooling fins. Place a thumb at each end of the exhaust vent, over the fan screw holes. Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
  • In this step, you'll push the logic board free from the clips holding it to the frame. Push only where directed or you may damage the fragile cooling fins.
  • Place a thumb at each end of the exhaust vent, over the fan screw holes.
  • Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
En este paso, empujarás la placa lógica para liberarla de los clips que la sujetan al marco. Empuja solo donde se te dirija o puedes dañar las frágiles aletas del ventilador.
Coloca un pulgar en cada extremo del escape del ventilador, sobre los orificios de los tornillos del ventilador. Presiona firmemente hasta que la placa lógica se desenganche.
Una vez que se liberan los clips, desliza la placa lógica afuera de la caja.
Al volver a instalar la placa lógica, asegúrate de apartar el cable delgado de la luz indicadora LED para que no se dañe.
[* icon_caution] In this step you will be pushing thestep, you'll push the logic board free from the clips holding it to the frame. '''Push only where directed''' or you may damage the fragile cooling fins.
[* black] Place a thumb at each end of the exhaust vent, over the fan screw holes. Press firmly until the logic board unclips.
[* black] OncePush firmly in the clips are freed, slide the logic board outdirection of the case.
[* icon_reminder] When reinstalling
ports until the logic board, make sureboard unclips and begins to hold the thin [guide|115309|LED indicator light cable|stepid=222050|new_window=true]slide out of the way so it doesn't get damagedMac mini.
