Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 15 guías que incluyan este paso.
Inglés
Español
Paso 4
Re-orient your iMac so it sits upright on the stand. Insert a plastic card up into the corner of the air vent slot near the top of the rear case. Push the card toward the top of the iMac to release the front bezel latch.
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
  • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
Insertar traducción aquí
