Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws. Do not fully remove the screws, just enough to be unattached from the  motherboard. Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
  • Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws.
  • Do not fully remove the screws, just enough to be unattached from the motherboard.
  • Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
Insertar traducción aquí
