Saltar al contenido principal
Inglés
Español
Traduciendo paso 2
Paso 2
Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons. Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack. Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
  • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
  • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Insertar traducción aquí
