Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Turn the turn signal bulb holder counterclockwise until it stops. Remove the bulb holder. Inspect the bulb. Check for broken filaments or cracked glass.
  • Turn the turn signal bulb holder counterclockwise until it stops.
  • Remove the bulb holder.
  • Inspect the bulb. Check for broken filaments or cracked glass.
  • Be sure to replace the turn signal bulb with the correct type for your Dodge. Using an incorrect bulb will result in shortened bulb or fuse lifespan.
Insertar traducción aquí
