Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
Rotate the outer ring of the headlight bulb holder counterclockwise to remove it. Carefully pull the headlight bulb holder out of its socket.
  • Rotate the outer ring of the headlight bulb holder counterclockwise to remove it.
  • Carefully pull the headlight bulb holder out of its socket.
  • When installing a headlight bulb, do not touch the bulb with your bare skin. Wear gloves when installing a new headlight bulb. Halogen bulbs are sensitive to skin oils, and the bulb may burn out quickly if you touch the bulb during installation.
  • If you accidentally touch the bulb, clean it immediately using rubbing alcohol on a clean cloth.
Insertar traducción aquí
