Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 4
If your Mac is not supported by this patch tool the patch tool will let you know that your machine does not support the Mojave patch. If that error is shown, it's the end of the road for your Mac. :-( Go back to the patch tool window and go the the menu bar These following steps are only necessary if you do not have a copy of the Mojave installer application.
  • If your Mac is not supported by this patch tool the patch tool will let you know that your machine does not support the Mojave patch. If that error is shown, it's the end of the road for your Mac. :-(
  • Go back to the patch tool window and go the the menu bar
  • These following steps are only necessary if you do not have a copy of the Mojave installer application.
  • Click "Tools" and then click "Download macOS Mojave" in the dropdown menu when it appears.
  • Click continue, and then select where you will save the installer.
  • I saved the installer to my desktop. Save it to wherever you want, just remember where you saved it.
Si tu Mac no está soportada por esta herramienta de parche, ésta te hará saber que tu computadora no soporta el parche Mojave. Si este error se muestra, es el fin del camino para tu Mac. :-(
Vuelve a la ventana de la herramienta de parche y ve a la barra de menú.
Los pasos siguientes son necesarios solamente si no tienes una copia del programa de instalación de Mojave.
Haz clic en "Tools" (Herramientas), y luego clic en "Download macOS Mojave" (Descargar macOS Mojave) en el menú desplegable que aparece.
Cliquea en continuar, y luego selecciona donde guardarás el instalador.
Yo guardé el instalador en mi escritorio. Guárdalo donde quieras, solo recuerda dónde lo has dejado.
