Saltar al contenido principal
Inglés
Español
Paso 2
Once the patch tool has finished downloading, open it the .dmg file and wait for it to mount. Inside the .dmg file, you will see an application named macOS Mojave Patcher. Double click it to open the application. If you get the error message "macOS Mojave Patcher can't be opened because it's from an unidentified developer.",(2nd image) you can bypass this by right clicking the application and clicking open (3rd image).
  • Once the patch tool has finished downloading, open it the .dmg file and wait for it to mount.
  • Inside the .dmg file, you will see an application named macOS Mojave Patcher. Double click it to open the application.
  • If you get the error message "macOS Mojave Patcher can't be opened because it's from an unidentified developer.",(2nd image) you can bypass this by right clicking the application and clicking open (3rd image).
Cuando la app ya se haya descargado completamente, abre el archivo .dmg y espera a que se monte.
Dentro del archivo .dmg verás una aplicación llamada macOS Mojave Pathcher. Ábrelo pulsando dos veces sobre él.
Si te saltara un mensaje de error como el de la segunda imagen puedes solucionarlo pulsando con el botón derecho del ratón y dándole a abrir (3ª imagen)
