Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners. Use the spudger to remove the siding from the bottom of the frame near the hinges. Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
  • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
  • Use the spudger to remove the siding from the bottom of the frame near the hinges.
  • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
Insertar traducción aquí
