Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right. Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red. Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
  • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
Insertar traducción aquí
