Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery. Remove the  8mm PH 1 screw that holds the plastic cover in place over the battery. Keep the screws together because the length of the screws will matter when you reassemble.
  • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
  • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
  • Keep the screws together because the length of the screws will matter when you reassemble.
Insertar traducción aquí
