Saltar al contenido principal
Inglés
Español
Paso 3
Remove the silver 15mm PH1 screw that holds the plastic cover in place over the battery. Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery. Place the screws accordingly because the length of the screws will matter when you reassemble.
  • Remove the silver 15mm PH1 screw that holds the plastic cover in place over the battery.
  • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
  • Place the screws accordingly because the length of the screws will matter when you reassemble.
Insertar traducción aquí
