Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 4
Locate the two speakers for this laptop that are connected above the battery by a thin red cord. Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place. Pull the left speaker up along with the red cord and leave it off to the right side.
  • Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
  • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
  • Pull the left speaker up along with the red cord and leave it off to the right side.
  • If you plan to disassemble the laptop down to the motherboard, you will also need to remove the two 3 mm screws holding the right-side speaker in place with a Phillips #0 screwdriver.
Insertar traducción aquí
